  • canadatom Friend
    #136750
    http://atgroup.ca/index.php
    Please check my module and header, there is a white background shift to right bottom position. Please help , Thanks
    John Wesley Brett Moderator
    #284792
    It’s not really a shift…you’re actually missing an image file in your TEMPLATES > JA RUTILE > IMAGES folder. You need one called “box-tr.gif”.
    It’s calling for it…but it is not finding it in that folder. The image will complete the dropshadow effect along the right side and bottom of the module.
    Have fun!
    John.
    canadatom Friend
    #284814
    <em>@jbrett 103992 wrote:</em><blockquote>It’s not really a shift…you’re actually missing an image file in your TEMPLATES > JA RUTILE > IMAGES folder. You need one called “box-tr.gif”.
    Have fun!
    John.</blockquote>
    thank you for your tip, but I do have this file, I installed this template as QUICK INSTALLATION PACKAGE, everything is there, and do you have any idea how to fix it?
    canadatom Friend
    #284818
    I recovered all the image files, seems OK now, thanks again for your help!
This topic contains 4 replies, has 2 voices, and was last updated by  canadatom 15 years, 10 months ago.
