  • mdmlex Friend
    #155213
    Dear All,
    could you please let me know how to change the white background of the header?
    Moreover, how I set the top margin to 0 and the grey background to white.
    Thank you in advance and best
    Max
    Don Lee Friend
    #358702
    <em>@mdmlex 198122 wrote:</em><blockquote>Dear All,
    Max</blockquote>
    To change background color, find this code to template.css file:
    #ja-header .inner {
    background: #FFFFFF;
    height: 60px;
    padding: 0 15px;
    position: relative;
    Then change the red key by your color value such as “red”, “blue”….
    Add below code to the file to reduce the margin:
    #ja-header {
    margin-top: 0 !important;
    Body background:: find this to change:
    body#bd {
    background: #A5A5A5;
    color: #555555;
    margin: 0;
    padding: 0;
    padunic Friend
    #359169
    and how i can apply some image in body background?
    Regards.
    Padunic
    Don Lee Friend
    #359194
    <em>@padunic 198748 wrote:</em><blockquote>Hi,
    Regards.
    Padunic</blockquote>
    I found this for you http://www.w3schools.com/css/css_background.asp
    Just read to try, then let me know if have any problem on that 🙂
    Also, this is an example:
    body#bd {
    background: url("../images/mainwrap-top.gif") no-repeat scroll center top transparent;
    color: #555555;
    margin: 0;
    padding: 0;
This topic contains 4 replies, has 3 voices, and was last updated by  Don Lee 14 years, 2 months ago.
