  • maxrows Friend
    #150375
    I can’t seem to make this simple change. How do I remove the “header” that sits at the top of the “body” section of JA Nickel. I can’t for the life of me figure it out. Thanks in advance.
    questbg Friend
    #340421
    Hi maxrows
    In Admin, use the ‘Menus’ function and open your main menu. Then, open each section/category in the list of menus that you want to remove the ‘title’ from.
    On the right hand side click ‘Parameters (System):
    Make sure that ‘Show Page Title’ is set to ‘No’.
    Hope this helps!
    Dear maxrows!
    Please follow the questbg’s solution to resolve the issue
This topic contains 3 replies, has 3 voices, and was last updated by  Saguaros 14 years, 7 months ago.
