November 4, 2007 at 3:09 am #123585
downloaded the JA Quillaja Template, and it looks nothing like on the demo. Only the banner is the same, how do i get the header and all those other features on it?
Michael Casha FriendMichael Casha
- 119 times in 1 posts
November 4, 2007 at 3:15 am #232140Are you sure you downloaded the quickstart, and not just the template?
November 4, 2007 at 4:23 am #232143<em>@MiCCAS 31167 wrote:</em><blockquote>Are you sure you downloaded the quickstart, and not just the template?</blockquote>
yer thats probably the problem.
Have just downloaded it before on the comp, what do i do with it? upload it as a template???
November 4, 2007 at 4:37 am #232144<em>@alenlisic 31170 wrote:</em><blockquote>yer thats probably the problem.
Have just downloaded it before on the comp, what do i do with it? upload it as a template???</blockquote>
Upload the whole package as you did when you installed Joomla, the procede with the installation like normal (http://www.yoursite.com/directory/to/joomla/installationNovember 4, 2007 at 7:22 am #232149<em>@MiCCAS 31171 wrote:</em><blockquote>Upload the whole package as you did when you installed Joomla, the procede with the installation like normal (http://www.yoursite.com/directory/to/joomla/installation</blockquote>
sorry, can you explain that a bit more further.I just had to click one button when intsalling Joomla through my host, got a feeling your not talking about the same thing.
November 4, 2007 at 7:52 am #232150<em>@alenlisic 31177 wrote:</em><blockquote>sorry, can you explain that a bit more further.
I just had to click one button when intsalling Joomla through my host, got a feeling your not talking about the same thing.</blockquote>
Ah ok, well you will need to upload all of the files in the zip file manually via FTP.November 5, 2007 at 5:00 am #232229gz could yours made this a bit more simple.
I’ve uploaded all the files via FTP in the templates folder, what do i do now?
November 5, 2007 at 5:06 am #232230<em>@alenlisic 31276 wrote:</em><blockquote>gz could yours made this a bit more simple.
I’ve uploaded all the files via FTP in the templates folder, what do i do now?</blockquote>
This is the easiest way…You need to upload the files in replacement of your current joomla site. Delete the old joomla install, then upload the quickstart in its place.
This topic contains 8 replies, has 2 voices, and was last updated by Michael Casha 17 years ago.
