  • cheappoet Friend
    #125311
    Hi, I am new here. I’ve installed this template, and I would like to change the color palette of links.. (from green/orange to magenta)
    how can I do this?
    (I am not familiar with css code, etc.. but I’ve worked a bit with dreamweaver)
    thanks in advance!!
    +_+
    mangoman Friend
    #238859
    Have you tried playing with the CSS file!!?? Look in the template folder/directory and you’ll find it – you’ll need to experiment to locate & edit the colors of the various elements.
This topic contains 2 replies, has 2 voices, and was last updated by  mangoman 16 years, 10 months ago.
