January 21, 2009 at 6:31 pm #137337
We’re banging our head against the wall on this one…
Our site has a title in the TITLE tag and we can’t seem to find where to change it…
* We have sh404sef extension installed but it does not seem to be in the settings
* Maybe our last webmaster hard-coded it in a file but we don’t know where
* We looked in the Edenite template menu and don’t see it thereHelp please 🙂
bennitos Friendbennitos
- May 2008
- 474 times in 407 posts
January 21, 2009 at 7:04 pm #287497You can set this in 404sef (it overrules the normal joomla settings)
In your joomla backend go to components and select 404sef.
Then click on:
Click here to switch to extended display (with all available parameters)Then click on META-tags, when you have that open click on home page META in your upperright corner.
Here you can set the tags you are looking for.,
January 21, 2009 at 8:45 pm #287505Hello Bennitos,
Thanks for your suggestion.
I tried this before and went ahead and did it again per your feedback, but no change. The home page still shows an old title that I want to remove, whereas the other pages/articles show their titles as the article title.
I’m almost thinking sh404sef is not actually running properly because:
* When I go to components/sh404sef/configuration and “disable” it, I don’t see any difference in the urls
* When I go to components/sh404sef/view-edit-urls, I don’t see any hits even though I’ve been clicking through the siteMaybe that gives you another idea of what might be up.
- May 2008
January 21, 2009 at 8:49 pm #287506Do you have the integrated “Search Engine Friendly URLs” in joomla 1.5 disabled?
January 21, 2009 at 10:47 pm #287516Hi again,
No, it is enabled. Out of curiosity since you mentioned it, I tried to disable it and then went to the sh404sef config and noticed a warning telling me SEF support in Joomla is disabled and to enable it from the global config.
- May 2008
January 21, 2009 at 11:32 pm #287526Hi Bennitos,
Yes, Joomla 1.5
sh404sef config shows installed version: Version_1.3.4 – build_288 –
mj1256 Friendmj1256
- June 2007
- 225 times in 118 posts
January 22, 2009 at 12:36 am #287536Hi,
Yes, global config/site/show title meta tag is NO
I had noticed how when it was YES, there was a META title=”…” in addition to the <TITLE> tag.
January 22, 2009 at 12:50 pm #287641Hi,
We did a installed 1.0.16_Beta – build_222 and it now works 🙂
Thanks for your help.
This topic contains 11 replies, has 3 voices, and was last updated by bennitos 15 years, 11 months ago.
