  • perezsimons Friend
    #154543
    Hi guys.
    I can’t figure out where to remove the Help for Haiti graphic on the homepage. It is a module? What’s the name?
    Many thanks!
    joomlageeks Friend
    #356393
    Yes, it is a module. It is assigned to “left” as the default module position.
    You can look at the module positions here http://www.joomlart.com/forums/topic/module-position-guide/
    Here is the Userguide for JA Pyro http://www.joomlart.com/forums/topic/ja-pyro-userguide/
    James
    perezsimons Friend
    #356395
    Thank you James. I’ve looked at both documents and still couldn’t find it. What’s the name of the module?
    joomlageeks Friend
    #356400
    Sorry the position of the module is “inset” and the name of the module is “Banner”.
    You can find this under the module manager menu in the Joomla administrator section.
    thanks
    James
This topic contains 4 replies, has 2 voices, and was last updated by  joomlageeks 14 years, 3 months ago.
