  • ockam Friend
    #180996
    I need to insert a slogan in the header between logo and module search.
    Also i want make more high the header.
    Where i find the file to edit them?
    And which strings i need to change?
    thank you in advance
    Stork11 Friend
    #468355
    <em>@ockam 339915 wrote:</em><blockquote>Hi
    thank you in advance</blockquote>
    Hello ockam,
    You can copy “/plugins/system/jat3/jat3/base-themes/default/blocks/header.php” file to “/templates/ja_rave/blocks/header.php” file. Then edit its content.
    Regards.
This topic contains 2 replies, has 2 voices, and was last updated by  Stork11 12 years, 2 months ago.
