  • trob3605 Friend
    #124992
    I set up a module in the right column for an ad service. However, when I enter the CSS/HTML code in the module copy box, it appears on the live site as code, not as the advertising it should be. I must be missing something — but can’t figure out what. You can see the empty module on the right column. Can anyone make a suggestion?
    travelswithtish.com
    Thank you.
    Menalto Friend
    #236449
    Did you turn the WYSIWYG editor off before you added the code?
    trob3605 Friend
    #236862
    No I didn’t turn it off. Looked through site — can’t find where to do this. Please let me know. Then, do I turn it back on after the ad copy appears — or leave WYSIWYG off?
    Thanks much
    trob3605 Friend
    #236868
    Ok, I found the WYSIWYG editor in mambots. Turned it off. Reposted ad code in module and published. Only code continues to appear on my site.
    Any idea why?
    hieunt Friend
    #237246
    Hi trob3605,
    Let me know how you entered the CSS/HTML code. I think the problem may be in your code, check the code again and take notice about your quotation marks.
    trob3605 Friend
    #237466
    Problem is now solved.
    Something magically happened. I rechecked that the WYSIWIG editor was off, recreated a new module, added the ad code and it appeared. Then I put the editor back on.
    Thanks for your suggestion. It helped.
    lgbtnation Friend
    #239852
    I’m sorry. you didn’t add on the forum how you turned it off. Where? Can everyone add how they did it, so someone else can find the solution? I would like to add ad code also, from google, etc. I’m in the module but I don’t see where you can turn it off?
    Also does anyone know to add a banner to this template?
    hieunt Friend
    #240020
    I think you can check WYSIWYG editor was off in global configuration of Joomla. In the drop down menu, choose site >> global configuration. In the row “Default WYSIWYG Editor:” choose No WYSIWYG Editor.
    mfcphil Friend
    #240078
    an easy way would be to use a module that you can simply add the code to
    see here
This topic contains 9 replies, has 5 voices, and was last updated by  mfcphil 16 years, 10 months ago.
