iluminada Friend
iluminada
- September 2010
- 2 times in 1 posts
April 18, 2012 at 12:03 pm #176246I sent a message before in the forum. My problem is the reseting of some styles. Sometimes I do changes and the next day the changes are like the begin.
khoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
April 18, 2012 at 4:31 pm #448935What files did you change?
iluminada Friendiluminada
- September 2010
April 18, 2012 at 4:40 pm #448938<em>@khoand 314537 wrote:</em><blockquote>What files did you change?</blockquote>
for example in nex>html>mod_janewspro>nex>styles.css there are:
.ja-zinsec .ja-zinsec-inner {
background: none repeat scroll 0 0 #FFFFFF;
border: 1px solid #E5E5E5;
margin-left: 5px;
margin-right: 5px;I change for:
border: 1px solid #FFFFFF;
margin-left: 5px;
margin-right: 5px;but the change is only for a moment, because the color line resets.
khoand Friendkhoand
- February 2011
April 18, 2012 at 5:04 pm #448949I changed your /templates/ja_nex/html/mod_janewspro/nex/style.css as you said, and it’s effect.
- 2008 times in 1700 posts
April 20, 2012 at 11:00 am #449298Did khoand help you out, iluminada? 😎
- September 2010
April 20, 2012 at 11:56 am #449307Hi, the problem is to work in the alternative theme and in T3 files. When I work in default template the reset don’t ocurr all time. At same time when I work directly in T3 files, the styles resets. Maybe it’s because I did not understand the actual role of T3 files, at not having a good tutorial in Spanish.
Saguaros ModeratorSaguaros
April 21, 2012 at 9:31 am #449474Hi iluminada,
It’s better to make an override file for different template you use and we should’nt make changes directly to T3 files. The new file will take precedence over the one in the plugin and when you update T3 plugin, it won’t be affected. With your above changes, it’ll be ok when you set JA Nex as default template, and when you change default template to another different from JA Nex, if it’s overrided, it will automatically takes file from base-theme in T3. Therefore, it will reset the default style as in T3 file.Hope you got the idea.
This topic contains 7 replies, has 4 voices, and was last updated by Saguaros 12 years, 8 months ago.
