April 19, 2009 at 3:00 am #140385
Hi first time user with your templates. Not my first time with Joomla and I have never seen this.
I am getting this.
Warning: Invalid argument supplied for foreach() in /home/content/c/o/m/communitycomp/html/templates/ja_opal/ja_menus/Base.class.php on line 62Here is the url
communitycomputerrepair.comI am hoping some one can help me.
April 19, 2009 at 2:34 pm #301849Nice support. So no one can help me on this?
John Wesley Brett ModeratorJohn Wesley Brett
- July 2013
- 645 times in 426 posts
April 19, 2009 at 2:42 pm #301851Try this: In EXTENTIONS > MODULE MANAGER > MAIN MENU
In that module look in the “Module Parameters” and make sure the “Menu Name” is correct and that you have Menu Style set to “List”.See if that doesn’t clear it up for you.
John.nguyenhuu quang Friendnguyenhuu quang
- 328 times in 288 posts
April 19, 2009 at 2:54 pm #301855hi. i think quickstart is better for you.
let to try it.
ThanksApril 19, 2009 at 3:13 pm #301858jbrett
Thank you for the reply The Menu Style set to “List”.
April 19, 2009 at 3:13 pm #301859quang268
quickstart is better for you.?
April 19, 2009 at 3:14 pm #301860install quickstart, it is better for you
- July 2013
April 19, 2009 at 3:17 pm #301861Then it’s probably a bad module installation. Happens…not often, but happens.
I agree with AtlantaJoomla…if you’re not too terribly far into the project…a good blow-out and Quickstart might be in order.These types of errors when they appear are a devil to swat…and usually caused by a bad install.
John.April 19, 2009 at 3:21 pm #301863Thank you I will try it
April 19, 2009 at 4:56 pm #301875i THINK i WILL STAY WITH http://www.rockettheme.com/
April 19, 2009 at 7:01 pm #301889no I can fix it for you.
pls contact via PMB.
ThanksJune 17, 2009 at 3:48 pm #308189Same problem with ja-tube after changing mainmenu name, ¿How can I remove this warning?
doktor101101 Frienddoktor101101
- June 2007
- 2 times in 1 posts
July 8, 2009 at 5:11 pm #310402I was having this problem and changed my menu name from main-menu to mainmenu and it worked.
Menus — Menu manager — then select menu you need fixed and make sure unique name is mainmenu.
Worked for me.
This topic contains 13 replies, has 5 voices, and was last updated by doktor101101 15 years, 5 months ago.
