  • elmundo_news Friend
    #157373
    Hi guys,
    I have a BIG PROBLEM, I have been working on a site for a newspaper for sometime already and suddenly when I tried to install another version of my site for testing inside another database in the same domain, my site LOST all the changes I have made! now I dont know how to retrieve all the customizations I had done to it. Please help me! Im not very familiar with joomla yet.
    Do you guys think that everything happens because I tried to work on both databases at the same time?
    I checked some of the changes I made to the template.css and are still there, I had added some modules and are still on the root foldes of the side but dont show on the joomla backend. I also had added an advertising block on top of the logo, the block seems to be there (because I cheked the layout settings) still but it does not show. I never bucked my site up.
    Any advice on this?
    Thanks in advance :((
    Phill Moderator
    #366514
    Without seeing it it is hard to say what you may have done. You may have worked on the wrong database at some point, you may have worked on the wrong files at some point. There really is no simple way of finding out. If you have no backup then speak toyour host and see if they do. Some hosts take backups some do not.
    Try looking at your site in a different browser first just to make sure it isn’t your browsers cache or some cookies muddled up.
    elmundo_news Friend
    #366532
    Phill Thanks for replying, I dont understand what happend, Im sure i was not working on the database affected. The other thing is that I had uploaded some modules which are still on the files but I cant have access to them through the administrator.
    For instance I tried to install the extplorer component but I did not let me because it said that the component already existed. That means that not everything is lost, but how do I get back to where I was??
    Does anybody want to take a look at my code? :((
    Phill Moderator
    #366537
    I really think in this case you should speak to your host to see if they have a backup.
    sharmaudit Friend
    #395942
    HOw to backup categories articals and main menu
    Phill Moderator
    #395970
    Just backup your entire site using the excellent Akeeba Backup – https://www.akeebabackup.com/
    elmundo_news Friend
    #396013
    thanks, I solved that issue already. By the time I wrote this thread, I did not know much about joomla. Now Im more familiar with it.
    Thanks for your help!
This topic contains 7 replies, has 3 voices, and was last updated by  elmundo_news 13 years, 5 months ago.
