  • vipcory Friend
    #169541
    I’ve search over dozens of threads cannot find how to make regular page, (not an article)… with images wherever I want in the page ?
    Also I do not want to use the ja_thumbnail. When I use that it still does not allow me to put the images exactly where I want.
    Should be pretty simple but I’m stuck any help?
    khoand Friend
    #418612
    I don’t understand what you mean clearly. Do you mean that you want to create a .html file?
    You turn ja_thumbnail plugin off.
    vipcory Friend
    #419892
    If I use the ja_thumbnail how do i arrange certain images..
    n6rej Friend
    #419906
    joomla does not use static files. All are created @ runtime via content.
    While you can add a block, that can contain static html I don’t see why you would do so. it kinda defeats the purpose of having a cms.
    I’d recommend you purchase the book in my signature to help you along. As khoand said you simply “turn off” unwanted items and turn on those you want to. This is the beauty of Joomla and other dynamic cms’s.
This topic contains 4 replies, has 3 voices, and was last updated by  n6rej 13 years, 2 months ago.
