  • sergiosp Friend
    #155420
    Help!! JA ORES in http://www.transportesmonges.com.ar my is not displayed in IE8.
    Install the plugin: System – IE8 Compatibility and did not work.
    What should I do?? can someone help??
    Sergiosp
    gray Friend
    #359537
    I could open your site in IE8.
    Also I checked for errors in JavaScript. I found only one:
    Uncaught exception: TypeError: Cannot convert 'Drag.Base' to object
    Error thrown at line 455, column 0 in http://www.transportesmonges.com.ar/templates/ja_ores/js/ja.ddmod.js:
    Drag.Resize = Drag.Base.extend({
    sergiosp Friend
    #359538
    Estimed Gray: Thanks for your prompt response!
    I sent an attachment image in mozilla and IE 8.
    IE8 is only in the menu and logo of the page.
    On the other hand … I have to do with errors? can you guide me to fix this?
    From already thank you very much for everything!
    Sergio
    9312
    1. image_mozilla
    2. Image_IE8c
    gray Friend
    #359545
    What version of IE8 do you use?
    And what happens if you remove (unpublish) the slideshow? If things go wright without it, what slideshow extension do you use?
    sergiosp Friend
    #359548
    hi!
    I’m using 2 modules: mod_jsn_imageshow_pro and ja-cpanel.
    The other modules I have disabled.
    IE8’s version is: 8.0.6001.18702
    but thanks again
    sergio
    gray Friend
    #359551
    What happens if you disable the mod_jsn_imageshow_pro ? Is the page rendered OK?
    sergiosp Friend
    #359564
    nothing happens, still do not see the page
    regards
    sergio
    gray Friend
    #359591
    I found a possible solution in other thread. Here is it:
    Please access the administrator >> Plugin manager and disable the System – Mootools Upgrade plugin and check this issue again. Do clear your cache also.
    sergiosp Friend
    #359611
    It worked! Thanks for your help
    sergio
This topic contains 9 replies, has 2 voices, and was last updated by  sergiosp 14 years, 2 months ago.
