  • th3who Friend
    #162874
    Hello I just Installed JA Tabs on my Xammp JA Social TEST SITE but I am stuck. I installed JA Teline IV quickstart to see the settings used for JA tabs so I could make all the settings the same on my JA Social TEST SITE but on the JA Teline IV quickstart JA Tabs shows a JA Tabs Position under: Module Parameters – Select a position. How do i make the JA Tabs Position so it will appear under the Select a position in the JA Tabs Module Parameters?
    himangi Friend
    #386797
    To use JA Tabs module in your template, you need to have tabs.php copied into yourtemple/blocks folder. You need to have <blockquote><block name=”content-mass-top” type=”tabs”>your position</block></blockquote>code in your template layout.
    The <blockquote>name=”content-mass-top”</blockquote>will change depending on where you want to place your tabs.
    To check the configuration of multiple tabs module please check http://www.joomlart.com/forums/topic/ja-teline-iv-userguide/
This topic contains 2 replies, has 2 voices, and was last updated by  himangi 13 years, 8 months ago.
