  • hush Friend
    #123690
    Hi ,
    I was follwed bellow stepes to move col1/left to left side of template.
    But it doesn’t work. Pls help me to solve this matters ASAP.
    my link is http://infonest.winhostinc.com
    Thank you
    Harsha
    Quote:
    Originally Posted by linkery View Post
    Move the column code:
    to the left side of the template in the template’s index.php file
    Just copy and paste it right below this section of code:
    Then go into the template’s CSS file (template_css.css) and look for this:
    Change it to:
    That should work…it did for me…
    kashxo Friend
    #232601
    Hello Hush,
    Please kindly note that our support rules will not included changing module positions and color scheme like you’ve requested at our site. Normally, when re-arrange module positions, it will destroy the whole template structure.
    However, please try the following and see if it can help you:
    Please open the index file in the templates/ja_hedera folder, go to line 243 and cut this code:
    [PHP]<?php if ($ja_left) { ?>
    <!– BEGIN: COLUMN 1–>
    <div id=”ja-col1″><div class=”shadow1″><div class=”shadow2″>
    <div class=”ja-innerpad”>
    <?php echo mosLoadModules ( ‘left’,-2 );?>
    </div>
    </div></div></div><br />
    <!– END: COLUMN 1–>
    <?php } ?>[/PHP]
    Goto line 190, and paste those code there, above the code:
    [PHP]<!– BEGIN: CONTENT –>[/PHP]
    Now refresh your site and see the result.
    And for the custom color in header, I’ll send you a tutorials later via PM.
    Goodluck, I hope this will work for you and it should work if you using original index.php file.
    PS: If you still got trouble or those above not work for you, please pm me the FTP details so I can access your site and help you there. Thank you.
    hush Friend
    #232603
    Hi kashxo, 🙂
    Thank you so much… It’s worked. When u get a chance pls send me the tutorial for the custom color in header.
    Thank you.
    Best Regards
    Harsha
    kashxo Friend
    #232619
    It’s a great new.
    I will mark this as solved. 🙂
    ricardomarx Friend
    #256638
    I try it at the Joomla 1.5 and “works”. I move the COLUMN 1 to the left BUT… if I disable all itens at the COLUMN 2 “right” the left back to the right. If I publish one module position at the COLUMN 2 (right) the COLUMN 1 (left), back to the left were I wanna keep it.
    I want just one clumns at the left (COLUMN 1) and keep “offline” the COLUMN 2 at the right.
    Any suggestion?
    The online problem (I will keep one item at the right column so you can see the problem better):
    http://arotec.bume.com.br
    Menalto Friend
    #270446
    did you manage to get this solved? if you did please mark this as solved, if you still have problems please post here again and add your live site url, joomla version and template version.
    ricardomarx Friend
    #283445
    No, I don’t solve it yet and need do this tomorrow ;(
    Joomla 1.5.8
    Thanks!
This topic contains 7 replies, has 4 voices, and was last updated by  ricardomarx 15 years, 11 months ago.
