  • sckavy Friend
    #154241
    I am using the JA Anion template and have selected the Light Color theme for a client site. I am trying to modify the blue color to match the logo. I usually just find the images and change the color there. The rest I look them up in the css files. This is what I have so far…(managed to change the search icon image).
    http://htn-id.com/hispanasunidas/index.php
    I am, however, having a hard time figuring this one out. This is my first T3 Framework Template – still figuring out all the ins and outs of it:) What I am trying to do is change the menu background to match the logo color. Any tips would be greatly appreciated.
    Thanks,
    gray Friend
    #355247
    Look in templatesja_anioncorethemes folder. All files which relate to a specific theme should be stored there.
    Hope it helps
This topic contains 2 replies, has 2 voices, and was last updated by  gray 14 years, 3 months ago.
