  • sergiosp Friend
    #164565
    modules do not work in SL-R can you help me?
    pritam Friend
    #393597
    Can you clarify that what is meaning of SL-R .
    sergiosp Friend
    #393727
    Hi Pritam! sorry wanted to write:SL1-R
    I Have Problems with modules SL1 SL1-R and-L, only seen one and Not Both at once.
    put the ja news frontpage and the modules are not displayed in the position SL1-R
    I hope you can help
    sergiosp Friend
    #393730
    I could solve part of the problem (I have no idea how I did), but now in the module JA NEWS FRONTPAGE, I get this error when I view the pictures:
    Warning: file_put_contents(/home/unaj/public_html/images/resized/images/stories/anibal_330_230.jpg) [function.file-put-contents]: failed to open stream: Permission denied in /home/unaj/public_html/libraries/joomla/filesystem/file.php on line 304
    Warning: file_put_contents(/home/unaj/public_html/images/resized/images/stories/zonceras-argentinas_300_230.jpg) [function.file-put-contents]: failed to open stream: Permission denied in /home/unaj/public_html/libraries/joomla/filesystem/file.php on line 304
    pritam Friend
    #394295
    I have seen your site http://www.unaj.edu.ar. Error which is showing in the front page might be it is missing some file. You need to check that which kind of File is missing and check the name of file and location.
    sergiosp Friend
    #394301
    What do I do so I know what the missing file? I’d appreciate your help in this task, I’m not very good at it.:((
    pritam Friend
    #394494
    You need to check the image path or name the image which is showing in the error.
    For example you can check the images/resized/images/stories/1631_60_60.png is correct or not.
This topic contains 7 replies, has 2 voices, and was last updated by  pritam 13 years, 6 months ago.
