  • aunstateboy Friend
    #170928
    I’ve tried everything to fix the module… but it just won’t seem to display correctly. As you can see in the attachment, only one column is showing… when there should be three.
    1. Screen-Shot-2011-11-21-at-9.56.46-AM
    Hi aunstateboy
    Have you cleaned your JaT3 cache ?
    aunstateboy Friend
    #425765
    Yes… several times. And, we’ve tested on several different computers. Did you view the page and it was displaying correctly with 3 columns?
    Could you check now ?
    aunstateboy Friend
    #425768
    Better! But now the fields aren’t filling.
    what you mean ?
    Could you read this guide ?
    aunstateboy Friend
    #425773
    That’s OK… I see that the “Show Featured Articles” had been turned off.
    Not sure what you did… but thanks!
    I have simply followed that guide that’s all
    aunstateboy Friend
    #425780
    You re-installed the module? I don’t really see anywhere on that guide link where it gives instructions for the NewsPro module.
    Chapter 3.3
    JA News Pro click on backend settings
    anyway we can consider this thread as solved ?
    aunstateboy Friend
    #425785
    Yes… thank you!
This topic contains 11 replies, has 2 voices, and was last updated by  aunstateboy 13 years, 1 month ago.
