  • visionsaga Friend
    #182477
    Please help me, i,ve got 2 problems with template JA ironis J2.5:
    1. Module Sponsored By (Advertising) can,t show if i use mozilla firefox. It can show only if we use google Chrome & Opera
    2. How to edit words in module footer?
    thanks & regards 🙂
    Sorry if my english bad :-[
    As you can see in the attached image i’m using Firefox and i can see your module sponsored by
    Could you be more clear ? what exactly want to edit ? maybe a screen shot will explain better your needs
    1. sponsored-by
    visionsaga Friend
    #473919
    <em>@pavit 347488 wrote:</em><blockquote>Hi
    As you can see in the attached image i’m using Firefox and i can see your module sponsored by </blockquote>
    You can see in the attached image, i have published the module
    but
    <em>@pavit 347488 wrote:</em><blockquote>Could you be more clear ? what exactly want to edit ? maybe a screen shot will explain better your needs</blockquote>
    1. ss2
    2. ss1
    3. Untitled-1
    Sorry i can see the module showed correctly
    About the second request what exactly you want to edit ? is not clear in the image attached
    1. firefox
    visionsaga Friend
    #473923
    <em>@pavit 347500 wrote:</em><blockquote>Sorry i can see the module showed correctly </blockquote>
    Oh My God, i forget…i have installed script on my Firefox that maybe block the module. so why it can,t show. Sorry :-[
    <em>@pavit 347500 wrote:</em><blockquote>About the second request what exactly you want to edit ? is not clear in the image attached</blockquote>
    Sorry, this is the right one 🙂
    1. s
    As Developer member You can remove footer “Designed by JoomlArt.com” and changed it to “Designed/Powered by YourCompany”
    To do this you need to download the PDF with instruction in your member area http://www.joomlart.com/member/member.php and in Payment History Tabs you will have the column PDF Copyright Removal with the PDF available to download
This topic contains 6 replies, has 2 voices, and was last updated by  pavit 12 years ago.
