  • douglas Friend
    #117958
    JA_Polaris comes with the default 3 columns which can collapse to 1, 2 columns.
    I want to change the layout of this template so that I have the columns in the standard layout mode:
    Left modules – main body – right modules
    Right now the default layout is: left modules – right modules – main body
    How do I change this?
    Any help appreciated.
    Doug
    Khanh Le Moderator
    #212528
    There are some thread in this forum taking about this. Please take a look and you will find the solution.
This topic contains 2 replies, has 2 voices, and was last updated by  Khanh Le 17 years, 11 months ago.
