  • sergiosp Friend
    #187785
    Hello Dear Teem of Joomlart! I need help! my site does not look good.
    Ja news feautured not showing well the items.
    I followed everything he says the userguide but have not had good results.
    You could help me fix this?
    Kind regards
    Sergio
    Ninja Lead Moderator
    #494147
    Can you tell me which position and menu item / page you assigned this JA New Feature module to? I shall help you to config it.
    sergiosp Friend
    #494193
    Dear Ninja Lead,
    I installed the quickstart folder.
    Then migrate to j2xml (plugin) Articles.
    The module that drives me crazy is “ja news featured” located in sl1-l.
    When you click on any of the major news … it takes you to that item and also does not display the picture.
    Kind Regrads an Thanks for all!
    sergiosp
    sergiosp Friend
    #494214
    Dear Ninja Lead,
    I have been able to fix the problem. What was happening had a direct relationship with the names of the Photographs. I had come up with the separate name (my flower.jpg) and was put with the name without separations (myflower.jpg).
    Thank you!
    sergio sp
This topic contains 4 replies, has 2 voices, and was last updated by  sergiosp 11 years, 7 months ago.
