  • sergiosp Friend
    #203965
    Hi friends!
    I want to edit JoomlArt Updater Service and put my username and password Joomlart get this sign: “Wrong username and password Login failed Please try again.”
    Can you help me?
    Sergiosp
    1. JoomlArt-Extensions-Manager
    I tested it with my account and it worked fine ( i updated the Ja_Google_map plugin ) so problem is into your settings, maybe try to verify the password you entered if is correct.
This topic contains 2 replies, has 2 voices, and was last updated by  pavit 9 years, 10 months ago.
