  • nospeakenglish Friend
    #119798
    Guys,
    I have installed joomla 1,000x but never with the quicktstart package, so I though tI’d ask here before I try.
    – Do I need to name the database/username and password according to anything? If so what is it?
    – Do I execute joomla.sql or the “ja_teline.sql” included? or both???
    Last time I tried it I got “ruthii_solarII” (default template) not found, i went to the admin mode and chagned it to the ta_teline and it worked, but it didn’t look anything like it should.
    then i foudn thaat ja_teline.sql fiel and executed that on top of the tables I had.. dind’t work… the i tried erasing the original joomla.sql tables and just running the ja_teline.sql and still didn’t work.
    Wha am I doing wrong?
    Thanks in advance!
    rob
    Hung Dinh Friend
    #218566
    You can upload the Quickstart package and install as new Joomla via Web installer
This topic contains 2 replies, has 2 voices, and was last updated by  Hung Dinh 17 years, 8 months ago.
