  • h_mechbal Friend
    #156531
    I’m using Purity_ii template, I have 2 languages on my site, radio button do not display correctly in the RTL language, for instance, a radio button “No” selected in the LTR version will show as not selected in the RTL version but the “Yes” will be display as selected.
    Any idea how to fix this issue?
    Thanks!
    Don Lee Friend
    #364032
    <em>@h_mechbal 203998 wrote:</em><blockquote>Hi,
    Thanks!</blockquote>
    It might be a translating problem when you translated in confusion at “yes” and “no” to your language.
This topic contains 2 replies, has 2 voices, and was last updated by  Don Lee 14 years ago.
