July 14, 2011 at 11:53 am #166289
Hi, all
I have two questions/issues with my slideshow and would appreciate some help.1: What size should the images be, and how do I change the size of my image to fit the slideshow, as you can see in my screenshot the only a small portion of the image is actually showing, with abd resolution.
2: When I click on the read more in the slide show it can either show in the main body of the home page or a new window, is there a way I can link it to open the artilce that is used as the slide similar to when you click on a menu item?
Screenshoot attached
pritam Friendpritam
- April 2011
- 125 times in 113 posts
July 15, 2011 at 12:31 pm #401323Hello omarzahid ,
To Help required with slideshow images
I am sending you url for background configuration for slideshow you can refer to that:-
http://static.joomlart.com/images/templates/J16/JA_Business/010.png
Also you can refer userguide for solution :-
http://www.joomlart.com/forums/topic/userguide-ja-business-template-for-joomla-2-5/July 15, 2011 at 12:50 pm #401327Hi, thanks for the reply but I have already gone through them and have got the slide show working, but the the issue us with the images I want to put on the slide show, ie how to fit my image
pritam Friendpritam
- April 2011
July 18, 2011 at 8:12 am #401610Hello omarzahid ,
1.Check the module has been enabled and placed on the page you want
2.Check the folder or image link is written correctly (e.g. images/IntroSlides displays all the images in that folder for the module I use)
3. Check the module width and height is set.
July 19, 2011 at 4:31 am #401761hi
as mentioned before, its all working, but the image dispaly is out if wack, as you can see in the screenshot provided. What Iam after is how do I know what size my images should be and how to change them to the requred size.Check point 2 un the section It Does not look like Demo Site? under the below link
http://www.joomlart.com/forums/topic/steps-for-making-your-current-site-to-look-exactly-like-demo-site-2/Demo content is missing, especially the images, please note that the images can be of specific size for example the slideshow module will require specific sizes of images as JA Anion requires images of 660×330 whereas JA xxx requires sildeshow image size of yy x yy.
AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by omarzahid 13 years, 4 months ago.
