  • nylonadmiral Friend
    #183904
    I’m helping a friend build an online magazine using the JA Teline IV template. I just installed SH404 and now the site displays really badly? You can see it here:
    dev.grampahands.com
    It started to look like this as soon as I installed SH404, even before I turned it on. Regardless of whether SH404 is activated, the display issues persist.
    Any help would be greatly appreciated.
    Many thanks.
    Stork11 Friend
    #479615
    Hello nylonadmiral,
    Does problem still occur if you try to uninstall sh404SEF and use default Joomla SEF?
    Regards.
    1. Untitled
    nylonadmiral Friend
    #479662
    Hi, thanks for the reply.
    I have tried fully disabling SH404 rather than uninstalling it.
    When I do this the problem persists. Would you suggest trying to fully uninstall it?
    Stork11 Friend
    #479748
    Hello nylonadmiral,
    To uninstall sh404SEF, you can go to “Extension Manager” / “Manage”, then filter by “sh404” keyword. Select all items in search result page and click on “Uninstall” buttion to uninstall them.
    Regards.
    1. Untitled
    nylonadmiral Friend
    #479815
    I have now tried fully removing SH404 and the problem persists.
    I am certain that the fault has been caused by the installation of SH404 because I had the site working perfectly, I made no other changes apart from installing SH404, then immediately after doing it the site displays completely wrong.
    After removing SH404 the problem persists so I’m now really stuck!
    Any help is greatly appreciated!
    Stork11 Friend
    #480147
    Hello nylonadmiral,
    I checked your site and saw that sh404SEF hasn’t uninstalled yet. Please try to uninstall it to see if problem is resolved or not.
    Regards.
This topic contains 6 replies, has 2 voices, and was last updated by  Stork11 11 years, 10 months ago.
