  • original.com Friend
    #1088947
    Greetings,
    Please help me setting the multilanguage EN and RO homepage like in the DEMO.
    B.T.
    In multilingual site, for each module/menu/etc… you should create 2 versions: 1 for EN and 1 for RO language. I just re-configured some modules on homepage so that it can display correctly in both languages now.
    You can do the same for others.
    original.com Friend
    #1089402
    B.T.
    You missed this spotlight module in ‘t3-mass-bottom’ position: http://prntscr.com/i8kc68
    I duplicated for you and it’s showing now.
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 6 years, 10 months ago.
