  • jiml Friend
    #164804
    I’m using joomla 1.6, ja purity II blue.
    I want to show the article-tools and article-info on the same line.
    Also, how can I add JFBConnect jfbclike into the same line.
    Atm it shows like this:
    PUBLISHED TUESDAY, 31. MAY 2011 20:09 BY ADMINISTRATOR
    [print] [mail]
    [like]
    I want it like this:
    [like] PUBLISHED TUESDAY, 31. MAY 2011 20:09 BY ADMINISTRATOR [print] [mail]
    I would really, really appreciate the help
    himangi Friend
    #395703
    Can you please post your site page url where I can see these tools and tell you exact styling changes to make it appear on a single line? Please make sure that all the tools are published on the url you provide so that later on there will not be any issue, even if you publish some tool..
This topic contains 2 replies, has 2 voices, and was last updated by  himangi 13 years, 5 months ago.
