  • henrik1782 Friend
    #173238
    I want to insert links like in the image but without the module frame.
    Help would be appreciated.
    <!-- TeamViewer Logo (generated at http://www.teamviewer.com) -->
    <div class="img-photo clearfix" style="position: relative; width: 234px; height: 60px;"><a href="http://www.teamviewer.com/link/?url=842558&id=262324206" style="text-decoration: none;"> <img src="http://www.teamviewer.com/link/?url=232691&id=262324206" alt="Download TeamViewer i fuld version" title="Download TeamViewer i fuld version" border="0" height="60" width="234" /> <span style="position: absolute; top: 30.5px; left: 60px; display: block; cursor: pointer; color: white; font-family: Arial; font-size: 12px; line-height: 1.2em; font-weight: bold; text-align: center; width: 169px;"> Download TeamViewer </span> </a></div>
    1. 26-01-2012-22-32-21
    pixelzombie Friend
    #435632
    Hi henrik1782,
    open up your module and insert into the field Module Class Suffix on the right hand side no-bg (Advanced Options). If there are allready classes defined, extend them divided with a space.
    1. no-bg
    henrik1782 Friend
    #435681
    Hi pixelzombie…
    Thanks for your answer but this didn’t make any difference
    1. 27-01-2012-12-38-13
    pixelzombie Friend
    #435683
    Could you please provide a link to your site? Got to see it live to tell you what to do 🙂
    Frank
    henrik1782 Friend
    #435684
    Hi Frank…
    here is a test site… test1.ftb-forum.dk
    pixelzombie Friend
    #435794
    The class is now moduletableno-bg which is kind of wrong 😉
    you’ll need to add a space before the module class suffix if it is the only one! I didn’t notice that. Insert
    no-bg
    Cheers
    Frank
    henrik1782 Friend
    #435804
    Ok… found out.
    clear in suffix did the trick.
    henrik1782 Friend
    #435807
    Hi Frank …
    You were of course right. I just added clear in front of no-bg and that made the is. I have corrected to no-bg.
    Thanks a lot for your effort.
    /Henrik
This topic contains 8 replies, has 2 voices, and was last updated by  henrik1782 12 years, 11 months ago.
