willylord Friend
willylord
- July 2007
- 8 times in 1 posts
February 12, 2013 at 12:01 pm #184892Hi, can you tell me how to move these modules? (see image)
I can give you my website admin password, if you can help me!
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
February 12, 2013 at 12:21 pm #483193Simply go into the module manager and select those modules. You will find a dropdown labelled position. Just select the position you would link those modules moved to.
Here is an image detailing the module positions
http://www.joomlart.com/static/guides/layout/?ja_teline_iv
And here is the Teline Guide – http://www.joomlart.com/forums/topic/userguide-ja-teline-iv-for-joomla-2-5/
willylord Friendwillylord
- July 2007
November 10, 2013 at 4:14 pm #511749Hi, sorry for late reply. But I have returned on this project today.
The problem persists. The position of modules is right1 and right2, yet.Can you verify here?
http://cloud.pupia.tv/index.php?option=com_content&view=article&id=47903:cure-termali-telese-successo-dell-iniziativa-buonanno&catid=539:comune&Itemid=619Thanks
- February 2014
November 11, 2013 at 7:48 am #511789Have you edited the code for your article layout at all? It seems that for all your articles the div is in the wrong place.
- July 2007
November 11, 2013 at 9:13 am #511807I don’t know.
What’s the name of correct position?I’ve tried to check it, but I can’t find it:
- November 2014
- 3854 times in 3563 posts
November 12, 2013 at 5:02 pm #512009I found the problem in the article detail page of com_content on your site
Try the following fix :
Open templates/ja_teline_iv/html/com_content/article/default.php file and add new “</div>” tag into end of this file
I fixed it on your site, please check and let me know if it helps
- July 2007
November 13, 2013 at 9:39 am #512077ninja lead;397603i found the problem in the article detail page of com_content on your site
try the following fix :
i fixed it on your site, please check and let me know if it helps
wow wow wow!!!!
Many thanks!!!AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 3 voices, and was last updated by willylord 11 years, 2 months ago.
Help to module moves
