  • sergiosp Friend
    #164485
    Hello!
    The apply button does not work in template manager. I can not change the color of it.
    Also not work the mega menu (no drop-down menu and therefore can not see the submenu)
    if module ja-news- frontpage, which was in SL1-l, it allowed me to utiilizar the SL1-R and I moved all the way down (below the footer) I can help?
    My site is http://www.unaj.edu.ar
    sergio
    thangnn1510 Friend
    #393134
    Hi Sergio!
    I have checked you site and see the apply button on template still works well:
    SAVE DATA SUCCESSFULLY
    Save general successfully
    Save profile default successfull
    sergiosp Friend
    #393260
    thanks for your help, I still have one problems: no display modules in SL-R
    can you help me?
    sergio
    thangnn1510 Friend
    #393751
    Hi Sergio!
    I have checked your site and seen that Sl1-R has been displayed. Have you fixed it? If so could you give us the solution?
This topic contains 4 replies, has 2 voices, and was last updated by  thangnn1510 13 years, 6 months ago.
