Viewing 15 posts - 1 through 15 (of 19 total)
  • lasor123 Friend
    #135297
    Hello.
    My JA Tabs will not load, appears on page User7 – what can I do …. I think it is a super module ….
    Best, Fortza
    http://www.fortza.dk
    Anonymous Moderator
    #279009
    Hi lasor123,
    Could you please send me your admin account via PM so that i could have closer look on the issue.
    lasor123 Friend
    #279028
    Hi JA Developer
    PM ?
    Best, Fortza
    lasor123 Friend
    #279197
    Hi again.
    I have sendt you a message via PM
    ////Fortza
    lasor123 Friend
    #279516
    Hallo…..
    …..anyone want to help me…..
    Best, Fortza
    Anonymous Moderator
    #279520
    Hi lasor123,
    I didn’t find your message in Private Messages.
    You can download JA Tabs Documentation for Joomla at link http://www.joomlart.com/forums/downloads.php?do=cat&id=90 for helpfull.
    lasor123 Friend
    #279569
    Hi JA Developer.
    I will try again…..thanks for your link……but i got this massage :
    lasor123, you do not have permission to access this page. This could be due to one of several reasons:
    Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else’s post, access administrative features or some other privileged system?
    If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
    Anonymous Moderator
    #279594
    Dear lasor123,
    where did you find this message?
    granitis Friend
    #279729
    <em>@JA Developer 91327 wrote:</em><blockquote>Dear lasor123,
    where did you find this message?</blockquote>
    I tried to download the manual from the link you provided and I received the same message…
    is there any help?
    Anonymous Moderator
    #279733
    Dear granitis,
    You must login before you want to download this package.
    lasor123 Friend
    #279749
    Hi again.
    I also used your link……and if u want to writ in this forum, u have to be lokked in 🙂 I´m lokked in…..so
    Best, Fortza
    lasor123 Friend
    #281909
    Hi again Developer.
    Any help on this JA Tabs issue…?
    Best, Lasor
    Anonymous Moderator
    #281915
    HI lasor123,
    It has some errors at your configuaration.
    Please try as follow:
    + Edit Fortza Tabs – pÃ¥ vej. module
    + In the edit page, Select an position to right (in demo is ja_tabs)
    + Select Type tabs to module
    + Select Position to user7. When you edit this module, you will see that the Position was using JAtab1.
    + Add some module use right position.
    Please check all your configuaration again.
    lasor123 Friend
    #282460
    Hi JA Developer.
    I´ll try – and thanks for your allways fast and good answers 🙂
    Best, Lasor123
    lasor123 Friend
    #282558
    <em>@JA Developer 94280 wrote:</em><blockquote>HI lasor123,
    Please check all your configuaration again.</blockquote>
    Hi JA Developer…..again 🙂
    I have set up as you suggested to me – now is the right position, as you said it should be. But I want JA Tabsat the bottom of the page, for it self …… with content. How do I add content, as in the demo …?
    Greetings, Lasor
    http://www.fortza.dk (you have all info. to connect)
This topic contains 19 replies, has 3 voices, and was last updated by Anonymous 16 years ago.
