  • hdavid90 Friend
    #964311
    hi, i want some help here, I want to remove intro text from homepage, just want to show title of the article. I atached an image so you can see wich text I want to remove. (just want the title in everything)
    Second, the social icon in the tope page, it doesnt let me edit, every time that i save, joomla crashed and received a message that cant access the web page
    No images attached at this post , could you also post a link to your website ? and if possible also a temp super user account for it to test the social icon module , since i cannot replicate your problem on my installation.
    hdavid90 Friend
    #964344
    hdavid90 Friend
    #964629
    Hi there
    Sorry for the delay
    I fixed social module in position head-social , if you want to edit it you should first disable your default editor from global configuration.
    Regarding intro text as i can see you already solved it.
    hdavid90 Friend
    #965959
    Thanks, can you tell me how you fix it? I always disable editor before doing that but no idea what happened
    hdavid90 Friend
    #965960
    Edit: Wrong post
    I disabled default editor and page cache plugin and added code to your custom-html module.
    as you can see, in mobile device , the homepage. the part of the logo is hiding some part of the slide. In some articles, that part hide the title of the article
    Since this topic has a different subject and it was solved, please open a new topic for your new issue.
    Best regards
This topic contains 8 replies, has 2 voices, and was last updated by  pavit 8 years, 3 months ago.
