rabarrig Friend
rabarrig
- March 2015
- 5 times in 2 posts
March 20, 2015 at 4:26 am #204850That’s it, guys… I’ve been bouncing around google results for a long time without luck… could somebody help me with this two problems?
THANKS!
March 20, 2015 at 9:43 am #563899Hello
It would be great if you will include url of your site, an illustrated screenshot of what problem you facing .
So i can check your problem and help you.rabarrig Friendrabarrig
- March 2015
March 22, 2015 at 7:54 pm #564137Thanks for your reply…
My site’s URL is http://www.aban.cl/
I just need to remove the “settings” link on top right.. i don’t want the people to be able to change site’s color
Also I need the price of every article to be hidden, since my site is going to be “request a quote” type..
thanks!
March 23, 2015 at 2:43 am #564160Hello For the settings color .
Go to module manager find the module settings .
Select position : toolbar-ct-3
Disable it .Price issue : {mijoshop id=40,price=1,rating=1,button=1}
I found the above code in article source ocde so you need to remove/comment it from article editor .rabarrig Friendrabarrig
- March 2015
March 23, 2015 at 4:32 am #564172THANKS A LOT…
I manage to resolve first issue. Second issue is not what you think, though.
The problem is this:
Although the article’s price is 0, it is displayed. I don’t want it to be displayed. I want people to request quotes for prices.
Cheers and thanks again!
March 23, 2015 at 7:59 am #564201Hello
Its the functionality handled by Mijoshop .
You can try the below code if it helps youAdd the below code in your custom.css file
.mijoshop .list-unstyled >li> h2 {display: none;}
Save and check frontend.
- March 2015
April 4, 2015 at 4:20 am #565698Awesome tweak, pankajsharma… thanks a lot!
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by rabarrig 9 years, 6 months ago.
Help with 2 things: remove "settings" and prices.
