Abdul Kadir Friend
Abdul Kadir
- 4 times in 1 posts
February 25, 2009 at 3:20 pm #138557I want a true 3 column layout of vauxite template, this has been solved for other templates like Kulanite. http://www.joomlart.com/forums/topic/convert-from-2-columns-layout-to-3-columns-layout/
Is it possible to create a similar layout for vauxite template?
Thanks in advance.
- 2008 times in 1700 posts
March 10, 2009 at 7:26 am #295137Hi,
Please backup your code and download my package and overwrite to your templates.
1. index.php file in templates/ja_vauxite folder.
2. template.css file in templates/ja_vauxite/css folder .
3.ja.ddmod.js file in templatesja_vauxite/js folder.
3 users say Thank You to JA Developer for this useful post
Abdul Kadir FriendAbdul Kadir
March 10, 2009 at 9:18 am #295177Thank you very much for your effort and thank you for the useful modification, i really appreciate it!
March 12, 2009 at 7:54 pm #295639I’ve tried this. It works ok when i have left and right modules both enabled. but when i only have one side enabled i get a mess . i need it so it works for:
left module, content
left module, content, right module
content, right moduleThanks.
lonnstrom Friendlonnstrom
- November 2006
April 24, 2009 at 4:26 pm #302450How is this marked “solved” and “sticky” if no one has replied to the problem? The member “davemars” has identified the issue with the one column breaking (gray stripe). I have the same exact issue and would like to know how to resolve it. Also, searching through this forum, I found several members identifying the issue, but no one responded to these. I think the issue lies with the fp news module not working if user 5 is not being used and only the narrower right column is used. Thanks you!
July 26, 2009 at 7:56 am #312248Hi,
i use the hack with the 3 column layout, but i need the second column (main content area) in width 100%. How can i change this in the template?
Regards,
MichaelAuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 6 replies, has 5 voices, and was last updated by dreamcatcher29 15 years, 5 months ago.
Help with 3 column layout
