  • dcasmr Friend
    #173828
    I am trying to publish large banners in Content mass top position. See it on top of my site. http://www.monburkina.com/
    I want sizes that flush perfectly with my
    modules without large gaps on the right or bottom parts of the site.
    Is there an optimal size to put on content-mass top? I can extend the width to 800 or 750 whichever is appropriate. I want to keep the height to around 300 or 350.
    Thanks,
    Luc
    TomC Moderator
    #438029
    There really isn’t an “optimal size.” It’s basically an issue of trial-and-error until you arrive at the result you like the best.
    It looks like you’re nearly there – perhaps a few additional adjustments.
    Also, if you want to adjust the padding above/below your banner image, you can refer to the following line within your template.css file
    at line 346
    <blockquote>
    #ja-header .main { padding: 15px 0; }
    </blockquote>
    Play around with the padding parameters until you get the result you want.
This topic contains 2 replies, has 2 voices, and was last updated by  TomC 12 years, 10 months ago.
