angie00 Friend
angie00
- November 2011
- 10 times in 1 posts
August 15, 2014 at 1:01 pm #200538@pankajsharma or anyone moderator:
We are having trouble with the Article Categories module that displays on front page. We have an article “Back to School 2014-15” in News category. We have News category in a menu item which works (link in footer of website), but whenever an end user clicks on the article it takes them back to the front page.
This article isn’t the only instance of this and we need some guidance!
August 16, 2014 at 3:17 am #546203Hello
the article are not opening because Homepage does not contain the mainbody container in JA Sugite template .
You need to create a menu and assign the category (news ) of those article that you selected in the article categories module ,
after that the article will redirect to the menu that you created for category news .Let me know if there is any confusion. 🙂
angie00 Friendangie00
- November 2011
August 16, 2014 at 7:31 am #546216<em>@”pankajsharma 441576″ wrote:</em><blockquote>Hello the article are not opening because Homepage does not contain the mainbody container in JA Sugite template . You need to create a menu and assign the category (news ) of those article that you selected in the article categories module , after that the article will redirect to the menu that you created for category news . Let me know if there is any confusion. :)</blockquote>
We do have category (news) in a menu so I guess I’m not understanding….
August 16, 2014 at 7:55 am #546219Please check the menu assigned template ,
Can you tell me the name if the menu, i will check it rite nowangie00 Friendangie00
- November 2011
August 16, 2014 at 7:48 pm #546229Communications > news
August 16, 2014 at 8:01 pm #546231<em>@angie00 441615 wrote:</em><blockquote>Communications > news</blockquote>
I HAVE NOT FOUND news category there . Also there are many menu with name news .
Please check it again and let me know.angie00 Friendangie00
- November 2011
August 16, 2014 at 10:08 pm #546235Sorry for the confusion. It is menu Communications > News & Headlines (the alias was news).
The link to News from footer menu (Resources > News) works just fine to show the articles from this menu item, however in the module it just goes back to front page.
August 18, 2014 at 4:52 am #546295Hello angie00 ..
JA Sugite is currently not compatible with Joomla 3.3.3 .
I checked your site is on Joomla 3.3.3 .
I suggested you to please install the previous backup of your site . with compatible version .
because if template is not compatible it can produce random problems .angie00 Friendangie00
- November 2011
August 18, 2014 at 1:07 pm #546367ok, so that is the cause of the module not working correctly?
August 18, 2014 at 2:02 pm #546383Hello .. it can be .the issue is the url routing , may be the file is not working with latest joomla3.3.3 .
I suggest you to check compatibility of the template, before update .angie00 Friendangie00
- November 2011
August 18, 2014 at 4:00 pm #546405Where does it show the compatibility? On this page it shows Joomla 2.5 and 3.
http://www.joomlart.com/documentation/joomla-templates/ja-sugite#system-requirementPankaj Sharma ModeratorPankaj Sharma
August 19, 2014 at 10:02 am #546525Hello the template is currently compatible with Joomla3.3.1
As the template will updated the notifications will comes on our Blog .
Please read our blogs for latest updates/news/tutorials
http://www.joomlart.com/blog
Edited …..
Please update the template … its compatible for j3.3.3 .
Check our blog.alexsmirnov Friendalexsmirnov
- July 2012
- 163 times in 119 posts
August 20, 2014 at 7:12 pm #546782Hi Angie,
To read the latest blog on JA Sugite update to compatibility with Joomla 3.3.3, please have a look at http://www.joomlart.com/updates/joomla-templates/ja-medicare-sugite-argo-wall-smashboard-biz-updated-for-joomla-3-3-3.
Hope this helps,
Regards,
Alex
AuthorPostsViewing 13 posts - 1 through 13 (of 13 total)This topic contains 13 replies, has 3 voices, and was last updated by alexsmirnov 10 years, 2 months ago.
Help with front page
