mayke Friend
mayke
- May 2008
- 13 times in 1 posts
November 14, 2008 at 6:51 pm #135379Hi,
I have change/rename the name folder of ja_sanidineii_light at templates folder,
I got the problem, I cannot change the Body Background images coz there is no images show up in the dropdown list, as shown on this warning :
JFolder::files: Path is not a folder /home/jadewall/public_html/community/templates/ja_sanidineii_light/images/background,
what do I have to do to fix this?Is there anything else that I have to fixed regarding changing the ‘ja_sanidineii_light’ name folder?
Thank you guys.
bennitos Friendbennitos
- May 2008
- 474 times in 407 posts
November 14, 2008 at 10:19 pm #279202not really an answer to your question but may i ask why you want to change the folder name of the template? what is the added value of doing that?
stuarta60 Friendstuarta60
- February 2010
- 7 times in 1 posts
January 1, 2011 at 2:35 pm #369578Hello,
I have exact same problem is there any fix please?
Saguaros ModeratorSaguaros
January 4, 2011 at 4:49 am #369924as reported
<blockquote>
</blockquote>your template is missing the background folder inside the templates/ja_sanidineii_light/images folder.Now you try to check again and put some background images in this folder
- February 2010
January 6, 2011 at 7:37 pm #370544Hi,
No, this folder is there. The problem only occured when I renamed the template name.
So my path is templates/new_template_name/images/background
All the background images are still in this folder too. Very strange.
Do you know what else this could be?
January 7, 2011 at 3:15 am #370586hmm, it’s a strange problem, i checked the installation package and it seems fine to me http://www.joomlart.com/forums/downloads.php?do=cat&id=10100
- February 2010
January 9, 2011 at 8:19 pm #370960Sorted!!
In the templatedetails xml file there is another reference to the ja_sanidineii_light template file name
change the “ja_sanidineii_light” reference in the below code to the new name of your template
<param name=”ja_bodybg” type=”filelist” default=”” directory=”templates/ja_sanidineii_light/images/background” label=”Body background” description=”Background image for whole site” />
This topic contains 7 replies, has 4 voices, and was last updated by stuarta60 13 years, 11 months ago.
