  • Dean Howarth Friend
    #164546
    Hi I have just strated using K2 with TelineIV and seem to be having some formatting problems?, is there any guide for K2 with Teline ?
    The social sharing, Icons, and font size etc dont work?
    pritam Friend
    #393875
    For user guide for K2 With Teline IV you can refer to this url:-
    http://www.joomlart.com/forums/topic/new-userguide-ja-teline-iv-for-joomla-1-5/
    Here you can see in the K2 Configurations at post 5.
    Dean Howarth Friend
    #393879
    Hi and thanks for the guide however this doesnt cover my issue as shown above?
    You can see here: http://www.discussuc.com/management/item/1-partnership.html
    I appreciate your thoughts
    humana Friend
    #393902
    by the K2 parameters the first setting is the K2 default CSS. Is it enabled? When it was disabled by me, my articles looked similar on my site. See the userguide by Joomlart: http://static.joomlart.com/images/templates/ja_teline_iii/teline4_globalsettings.png
    Dean Howarth Friend
    #393980
    Thanks that fixed, sorry I had assumed TIV had K2 CSS built in, so didnt enable it, when I did the site went crazy (ie8), it has setlled once i re-enabled Join and Compress CC in the template ?
    Thanks Again
This topic contains 5 replies, has 3 voices, and was last updated by  Dean Howarth 13 years, 6 months ago.
