  • javierl Friend
    #183175
    I have installed the quick installation package for JA Elastica (thanks to TomC for the guide). I think I may have done something wrong inadvertedly, because I can’t find the buttons that changed the layout (desktop, extra-wide, tablet, etc.) on the upper right corner of the screen.
    In template manager –> JA Elastica Default –> Profiles –> Default –> User tools , I have ALL the options with the radio button “Show”, that’s why I don’t understand.
    The other related problem is that in fact, I have one iFrame wrapper. I managed to work it out fine, except that is a little too big (wide). I would like that the screen had 4 columns (4 x 240 px = 960 px) and 1 block to the right to display a login form. However the layout seems to be 2 columns (480 px) + the other column with the login form. That forces me to use the horizontal scroll wich looks pretty bad.
    Can you help me to fix this? Thanks in advance
    HI javier,
    This JA Elastica is responsive template, it doesn’t support to show these usertool options in frontend like other older built with JAT3 template.
    Please check out this userguide to know more about layout of this template: http://wiki.joomlart.com/wiki/JA_Elastica/Grid_and_Layout
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 12 years ago.
