  • swissa Friend
    #171552
    I’ve tried doing it all on my own but now at the stage where I need some help! Treat me gently I’m not technical! 🙂
    JA Masshead Module
    If I enter no text in either the default title or the default description I can still see something on the masshead – where text would have been. For me a picture alone is enough but unlike the Slideshow there are no buttons to push to not publish text. Is there a way that I can have nothing on the masshead?
    Right, now to the real problem. It has to have been me that somewhere down the line that caused the problem but I have no idea what I did. I have a multi-language site and followed the post on here to set-up a second template for one of the languages.
    That works except that when I click on categories in the left side, instead of jumping to a page with the masshead and the category picked I jump to the category picked but the slideshow returns at the top. The url does not show jshopping in it but my homepage does. Just to clarify the slideshow appears on all pages (set to only homepage) instead of the masshead.
    What have I done wrong?
    Thanks in advance for all your help.
    swissa Friend
    #428556
    I’d really like to thank Joomlart and everyone else who has taken the time to respond and offer help. It has been enlightening that so much is given so freely to a new and inexoerienced member. Really inspiring.
    swissa Friend
    #428810
    Where’s the emoticon for “tumbleweed”?
    TomC Moderator
    #428818
    <em>@swissa 288055 wrote:</em><blockquote>Where’s the emoticon for “tumbleweed”?</blockquote>
    I believe it’s within the same folder as the emoticons for “patience” and “gotta love that sarcasm.”
    TomC Moderator
    #428819
    <em>@swissa 287536 wrote:</em><blockquote>
    If I enter no text in either the default title or the default description I can still see something on the masshead – where text would have been. For me a picture alone is enough but unlike the Slideshow there are no buttons to push to not publish text. Is there a way that I can have nothing on the masshead?[/quote]
    When you made and saved your changes, did you also clear your JAT3 and browser cache before refreshing your page?
    Perhaps you can post a screenshot of the issue you are experiencing?
    swissa Friend
    #428820
    <em>@TomC 288065 wrote:</em><blockquote>I believe it’s within the same folder as the emoticons for “patience” and “gotta love that sarcasm.”
    :cool:</blockquote>
    Nestling alongside “low expectation”
    It seems to be a subject that gets lots of views and no comments i.e. http://www.joomlart.com/forums/topic/home-page-worries/ or maybe even this one http://www.joomlart.com/forums/topic/multilanguage-megamenu/
    Can’t find a faq for it or anything in the template install guide either.
    A drowning man’s gonna shout Tom. You may not have given me the answer I’d like but at least I now know SOMEONE is listening!
    swissa Friend
    #428821
    <em>@TomC 288066 wrote:</em><blockquote>When you made and saved your changes, did you also clear your JAT3 and browser cache before refreshing your page?
    Perhaps you can post a screenshot of the issue you are experiencing?</blockquote>
    I haven’t had time to try it yet but I think khoand posted a possible solution. http://www.joomlart.com/forums/topic/ja-masshead-2/.
    swissa Friend
    #428999
    Had a discussion with support guys and will work on their suggested solution over the weekend so we can put this on hold for the moment.
    Fingers crossed. 🙂
    TomC Moderator
    #429000
    <em>@swissa 288276 wrote:</em><blockquote>Had a discussion with support guys and will work on their suggested solution over the weekend so we can put this on hold for the moment.
    Fingers crossed. :)</blockquote>
    Sounds great . . . And if/when you arrive at your solution, perhaps you can share it here – so that others who may experience a similar issue can learn and benefit from your experience and resolution.
    swissa Friend
    #429002
    Will do. Along with some more sarcasm if you like?
    :p
This topic contains 10 replies, has 2 voices, and was last updated by  swissa 12 years, 11 months ago.
