angie00 Friend
angie00
- November 2011
- 10 times in 1 posts
August 21, 2013 at 12:39 am #189906When viewing site in mobile view it is cut off and only shows about a third of the site.
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
August 21, 2013 at 9:51 am #503001Hi angie00,
This issue is casued by the HLwrapper section which has been displaying the login module on mobile view, since the template layout will be cut when the login module is being aligned to the right. In addition, this HLwrapper is a fixed section so that i will break the responsive layout of our JA University template. In this case, i suggest you to hide the login module on mobile view by adding below codes into templatesja_universitycsslayout-mobile.css file:
#HLmodule {
display: none !important;
}Clear JAT3 cache then. This will help your website look better on mobile view.
angie00 Friendangie00
- November 2011
August 22, 2013 at 2:16 am #503069Sadly that didn’t do anything for our site.
- May 2015
August 22, 2013 at 2:19 am #503071Hi angie00,
Well, can you send me PM with the super admin or activate your given account ? Maybe I will give your better solution after checking your website.
- November 2011
August 28, 2013 at 11:24 pm #503832Thanks I PM you the site
- May 2015
August 29, 2013 at 2:16 pm #503955Hi angie00,
I saw the message you sent me but there is a website url. Can you send me PM again with your website’s admin login ? I will check and give you the suggestion on this issue.
- November 2011
August 31, 2013 at 12:45 pm #504186Thanks, I pm you with the details.
- May 2015
September 3, 2013 at 2:18 am #504294Hi angie,
We came back. Can you check the admin login you created for me ? It is invalid now, i got this message when i tried to access the website’s backend.
<blockquote>Login denied! Your account has either been blocked or you have not activated it yet.</blockquote>
- November 2011
September 4, 2013 at 3:20 pm #504582Ok, please try it now…
- May 2015
September 5, 2013 at 3:30 am #504632Hi angie00,
The responsive issue of your website not only is caused by the fixed dropdown login module but also the top-bar menu above the header. In this case, we suggest you to test your website again without the top-bar menu and dropdown login module. We will back to help you correcting this issue if exists when you removed these modules.
- November 2011
September 8, 2013 at 10:23 pm #504963We disabled and it still doesn’t show the whole page of the site on a mobile device. We uploaded a test site within our domain without the bar if you would like I can pm you that link.
- May 2015
September 9, 2013 at 3:37 am #504980Hi Angie,
Thank you for creating the test site without the bar. I will be happy to check this issue again when you send me PM with the credentials of that test site.
- November 2011
September 9, 2013 at 6:22 am #505013Thanks, I’ll pm you.
- November 2011
September 12, 2013 at 12:14 am #505436Hi, we do have the latest template and I p.m. the details for logging in again. Thanks.
- May 2015
September 12, 2013 at 8:31 am #505515Hi angie00,
Thank you for sending me the admin login again and your patience. I don’t want to blame you on this incompatible issue, but i should say that there is a css style missing of your customized logo, spotlight and main on mobile view, that is why the website is cut with responsive. Here are the detailed steps to solve your issue:
1. Open /templates/ja_university/themes/School/css/template.css file, then change lines:
body.bd .main {
width: 1000px !important;
}to
body.bd .main {
width: auto;
}2. Open /templates/ja_university/css/layout-mobile.css, change lines:
#ja-topsl .ja-box {
width: 50% !important;
}to
#ja-topsl .ja-box {
width: 100%;
}Then add below codes into this layout-mobile.css file too:
#ja-header h1.logo {
height: 100px;
h1.logo a {
background: url(../images/logo.png) no-repeat left;
width: 310px;
height: 88px;
background-size: 100% 100%;
}ul.department-list li {
display: inline-block;
float: left !important;
}Clear JAT3 cache after saving changes, your website will display fine on mobile device then. Lets tell me if you need further assistance on this concern.
This topic contains 15 replies, has 2 voices, and was last updated by phong nam 11 years, 2 months ago.
