August 29, 2010 at 4:10 am #153897
Hello, I want to move a module block next to the slideshow and remove the right block so that I can have a larger article space. I was hoping that with the new JAT3 that I would be able to do this pretty easily but so far I haven’t had much luck. I have read the wiki and watched the tutorial video you posted on youtube but still haven’t had any progress.
Visually what I want:
Any help is greatly appreciated!
gray Friendgray
- October 2009
- 292 times in 230 posts
August 29, 2010 at 8:09 am #354020I had the same task, but could not accomplish it as I wanted. It seems that T3 framework does not give you a possibility to add new position in the middle.php (at least without hacking). The pre-defined ones are content-mass-top, content-top, left & right – that’s all (please correct me, if I’m wrong).
So, a sort of solution could be adding user1 and user2 blocks above the main (middle) blocks.
Default layout is
<?xml version="1.0" encoding="utf-8"?>
<layout>
<name>Default</name>
<description>Default layout for JA Anion template</description>
<block name="header" type="header"></block>
<block name="cpanel" type="usertools/cpanel"></block>
<block name="mainnav" type="mainnav" markup="3"></block>
</blocks>
<blocks name="middle" colwidth="20" markup="3" fixheight="1">
<block name="content-mass-top" style="raw">content-mass-top</block>
<block name="content-top">content-top</block>
<block name="inset1" width="20">left</block>
<block name="right1" width="30">right</block>
</blocks>
<block name="botsl" type="spotlight" markup="3">user5,user6,user7,user8</block>
<block name="navhelper" type="navhelper" markup="3"></block>
<block name="footer" type="footer" main-inner="1"></block>
</blocks>
</layout>
My version is (slideshow is assigned to position user1, another module – to user2)
<layout>
<block name="topsl" type="spotlight" special="left" specialwidth="75">user1,user2</block>
</blocks>
</blocks>
</blocks>
</layout>
1 user says Thank You to gray for this useful post
August 29, 2010 at 9:12 am #354024Thank you! This is exactly what I was looking for!
gray Friendgray
- October 2009
August 29, 2010 at 9:26 am #354025<em>@uzeal 192048 wrote:</em><blockquote>Thank you! This is exactly what I was looking for!</blockquote>
I’m very glad that my solution was helpful 🙂
To JA Admins: Still, I’d like to clarify are the ‘content-mass-top, content-top, left & right’ blocks pre-defined and I could not without hacking add any new blocks in middle.php?
If it requires hacking – could you please provide a short guideline? Thanks!
November 9, 2010 at 12:57 am #362012there is content-mass-bottom also.
This topic contains 5 replies, has 3 voices, and was last updated by xarxa palestina 14 years, 1 month ago.
