  • modified Friend
    #155519
    I want to make my site look exactly, like it does in the demo, is there a diagram that tells you all the positions for the modules etc…
    thanks
    Arvind Chauhan Moderator
    #359862
    Module position guides are posted in each forum as sticky thread. I have moved your thread to Sanidine forum and if you look at the forum, one of the sticky thread is about the module position guide.
    here is the link >> http://www.joomlart.com/forums/topic/ja-sanidine-ii-module-position-guide/
    hope it helps
    Arvind
This topic contains 2 replies, has 2 voices, and was last updated by  Arvind Chauhan 14 years, 2 months ago.
