  • mangoman Friend
    #139432
    Using _hilite module class suffix, I cannot achieve the color background.
    See: http://www.elcofredelucia.com >> Suscribete al Boletín (Communicator Subscribe Module)
    Any suggestions?? :((
    Thanks in advance!
    John
    anisjolly Friend
    #297260
    hey mangoman
    what background color are you trying to achieve??
    do you have any examples on your site?
    thanks
    anis
    mangoman Friend
    #297590
    Thanks for your help…
    On the homepage here you’ll see “Suscríbete…” – that module class suffix should be _hilite but it’s not working (regardless of color, but it’s set to pink as default). >:(
    According to the documentation, the background of the module should appear just as the “FAQ module” displayed in the JA_Trova demo.
    I checked the parameters and the CSS – it all look OK (I haven’t changed anything) but it’s not displaying….!
    Any ideas why?
    John
    mangoman Friend
    #299116
    I went searching again and learned how to fix/do this!
    The problem is not in the module class suffix, it’s located in the index.php of the template – it seems that for design reasons, the left and right module positions are styled differently. I can “see” why, but for my purposes I desired them to look the same. 🙂
    Solution is here:
    http://www.joomlart.com/forums/topic/modules-color/
    Hope that helps others looking for a similar effect!
    John
This topic contains 4 replies, has 2 voices, and was last updated by  mangoman 15 years, 9 months ago.
