  • dcasmr Friend
    #191894
    I am trying to build a Jreviews type website and want to position the modules as much as this: see the demo of jreviews.
    http://demo.reviewsforjoomla.com/
    I need help with ideas to publish my modules if that it possible. Obviously, I want to use JA MAGZ because of its features.
    Currently, the titles of my modules do not show and I don’t show:
    see here: http://www.leburkina.net
    You can add suffix: ?tp=1 at the end of your site URL to see how / where module positions locate, then you can assign module from jreviews to position you desire: http://www.leburkina.net/?tp=1
    With problem of showing module title, did you try to apply the solution in another thread you posted.
    dcasmr Friend
    #510850
    Hi Saguaros,
    Thanks for the pointer… That solution consisted of putting a module.php file under /templates/html folder for JA University. I tried to do same for JA Magz and does not work…I don’t why the modules names kept disappearing….
    thanks
    Could you pm me admin and ftp account of your site? I will take a look at this
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 11 years, 2 months ago.
