  • tenaki Friend
    #152533
    Hi I have the template set at widescreen but I need to make the right hand column narrower giving more room for content. What would be the best way to reduce the column width.
    Pls
    – Open templates/ja_template_name/layouts/default.php file, at the begin of file, find following code line:
    $this->_basewidth = 20;
    here you change 20 to your size.
    and pls kindly read the wiki in detail http://wiki.joomlart.com/wiki/JA_Template_Framework/Guides
    tenaki Friend
    #349914
    Thanks for the link and code
This topic contains 3 replies, has 2 voices, and was last updated by  tenaki 14 years, 5 months ago.
