  • soulroll Friend
    #128717
    Hi, i have problems when i make the 1.5.2 quickinstall.
    everything works with the instalation but the modules like it supposed to be in the demo are not in.
    i see them in the folder but i cant see them in the backend.
    HELP!!!!!!!!!!!!!!
    Can i reinstall the modules new? manually how?
    Menalto Friend
    #249832
    You can reinstall them no problems, is this for 1.0.xx or 1.5.3?
    It sounds like you didnt install the sample data, if you did the modules should be there
This topic contains 2 replies, has 2 voices, and was last updated by  Menalto 16 years, 6 months ago.
