ae.sakon Friend
ae.sakon
- August 2017
November 2, 2017 at 6:15 pm #1071959Greetings.
JA Google Analytics for Joomla is working fine but on the front-end is not. I had tried to put the access code again and again but it’s failed.
I need your help to check the root cause is from? Thank you.
Luna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
November 3, 2017 at 10:37 am #1072119ae.sakon Friendae.sakon
- August 2017
February 1, 2018 at 5:07 am #1089535Hi,
I had tried again to run the JA GOOGLE ANALYTICS on my sites. Currently, the module is running but it’s not capture the audience views.
Thank you.
ae.sakon Friend
ae.sakon
- August 2017
February 1, 2018 at 5:10 am #1089539Saguaros ModeratorSaguaros
February 2, 2018 at 7:06 am #1089743Hi,
Kindly share the credentials of your site so I can check for you.
- August 2017
February 2, 2018 at 9:08 am #1089782This reply has been marked as private.ae.sakon Friendae.sakon
- August 2017
February 5, 2018 at 2:50 am #1090027This reply has been marked as private.Saguaros ModeratorSaguaros
February 5, 2018 at 2:59 am #1090028Hi,
I still don’t see the API configuration for this module on your site, could you set info for this first? http://prntscr.com/ia7g0l
Check out the guide of this module here: https://www.joomlart.com/documentation/joomla-module/ja-google-analytics-for-joomla.
- August 2017
February 5, 2018 at 3:23 am #1090031This reply has been marked as private.Saguaros ModeratorSaguaros
February 6, 2018 at 7:12 am #1090274Hi,
Could you update latest version for this module and add the API configuration in backend settings of this module?
- August 2017
February 6, 2018 at 8:13 am #1090279Hi,
I already tried to update it but it’s failed. Please kindly see the picture that I attached to you.
I don’t know why JA_GA not keep the latest version that I updated despite the fact I already updated it.Please help me check.
Thank you.
Mo0nlight ModeratorMo0nlight
- 99 times in 97 posts
February 7, 2018 at 9:30 am #1090549Hi.
i had put some api key to JA Google Analytics Module
and changed module position to : position-5And it’s working.
You could try to put another api.
And maybe it’s relate to your ip address. you should try a domain address then ?
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 11 replies, has 4 voices, and was last updated by Mo0nlight 6 years, 10 months ago.
Hi, I have a problem with "JA_GA_ERROR_NOTICE, please Refresh".
